I would like to setup a scene that is triggered with motion sensor.   But it should only run the scene between 8 am and 9 am an only once per day.   I have it work for the entire process, but it runs every time the motion is tripped.  Two things I am looking to solve.
1)   How can I have it only run between 8 am and 9 am
2)   Only run once per day?
Basically want motion sensor to open blinds in living area when i first walk in to living area in the morning.
Kyle
    Right i have the run only between  8 am and 9 am part now with variables active/inactive, just need the run only once part.
    1. Create a Global Variable with the name Blinds.
    2. Use this code (change the ID of the motionsensor and ID of the blinds:
    This should do the trick.
    Thank you very much
     for the reply!
    Ok i have created the variable called Blinds and set the value to 0 (standard).
    I have then created a Lua Scene and added your code to it and changed the two ID as shown above the xxxx but its not triggering the blind to even open.
    Any idea what it could be?
    Thanks in advance!
    Kyle
    Can you post your scene?
    Try this (more logging):
    If triggered it says "Motionsensor trigger", if the if clause  passes it says "Blinds open", otherwise "Something else".
    %% properties
    150 value
    %% globals
    startTime = "08:00"
    stopTime = "11:00"
    currentDate = os.date("%x");
    currentTime = os.date("%H:%M");
    fibaro:debug("Motionsensor trigger")
    -- check script instance count in memory
    if (tonumber(fibaro:countScenes()) > 1) then
      log("Script already running.");
      fibaro:abort();
    local sourceTrigger = fibaro:getSourceTrigger();
    if sourceTrigger["type"] == "property" and fibaro:getGlobalValue("Blinds") ~= currentDate and currentTime >= startTime and currentTime < stopTime
    then
      fibaro:call(221, "open");
      fibaro:setGlobal("Blinds", currentDate)
      fibaro:debug("Blinds open")
      else
      fibaro:debug("Something else")
    [DEBUG] 10:49:53: Motionsensor trigger
    [DEBUG] 10:49:53: Something else
    [DEBUG] 10:50:24: Motionsensor trigger
    [DEBUG] 10:50:24: Something else
    Thanks so much!
    But it is not working, should say once "Blinds open" (i see that you adjusted the time till 11:00, so that it should met)???
    If it is not working could you change
    to
    if fibaro:getGlobalValue("Blinds") ~= currentDate and currentTime >= startTime and currentTime < stopTime
    Yes it's not working, yes adjusted time to test now
    Ok let me make changes one second.
    kyle
    Ok made changes but still "something else"
    [DEBUG] 10:59:16: Motionsensor trigger
    [DEBUG] 10:59:16: Something else
    [DEBUG] 10:59:46: Motionsensor trigger
    [DEBUG] 10:59:46: Something else
    Again massive thank you for your help
    Extra debugging
    [DEBUG] 11:08:39: Motionsensor trigger
    [DEBUG] 11:08:39: 07/23/16
    [DEBUG] 11:08:39: 11:08
    [DEBUG] 11:08:39: Something else
    The variable is showing the following now instead of a "0"
    Should put it to 0 again, it already met the statement once and it will only run once (a day)
    Ok changed to "0".
    Debugging now showing the following:
    [DEBUG] 11:16:36: Motionsensor trigger
    [DEBUG] 11:16:36: 0
    [DEBUG] 11:16:36: 11:16
    [DEBUG] 11:16:36: 07/23/16
    [DEBUG] 11:16:36: Something else
    Did you adjust the time to 12:00? it is past 11:00
    No i did not change it.....
    It now works!
    Gracias Gracias Gracias  :-D
    Great!
    You can remove the extra lines of debugging if you want.
    Will do, again thank you very much for your help with this.
    Much appreciated.
    Kyle
