[SOLVED]Wall plug problem - no illumination [solved]
on my Fibaro wall plug module LED ring illumination stopped working. I checked all parameters and everything looks fine. Does someone has the same problem?
Thank you
5 answers to this question
Guest FredrikKarlsson
Check the manual. You can disable the ring led via the button, so maybe you've done that without noticing?
I got the same problem, Mine was working for about 8 months and then its stopped working as it should,
When i use the button on the wallplug it it flashes up one time and then it goes dark
press and hold button till it will blink
Thanks that worked
Maby an update to the manual?
    It worked!
    Thank you for your help @FredrikKarlsson and @A.Socha
