i cannot select any Hue lights for my home screen (where there are 6 positions where you can add a device for easy accesibility)
i can only control them from 'rooms'
Klaas
8 answers to this question
Hi, today it is not possible to add these things on front screen: Virtual devices, Plugins, Cameras(iPad).
What version of the app do you use? Did you update the app recently?
I got the latest version but still cant get Virtual devices, Plugins, Cameras on the first screen. How?
Such function is not available in our app for iPads. So you cannot add plugins to the list of widgets.
As far as I am informed there is no plans to implement such function at the moment.
Sorry, double post - Delete
(See post below instead).
Edited by robw
Why is it not supported? I'd say it is a basic and needed function, that via an app be able to control the units you have in you Fibaro system! With my Android phone I get access to everything (virtual devices, Logitech plugin etc), but not via my iPad. When Iaunch that, suddenly I can't do a third of what I can do with Android and the web ui.
Fibaro, do some re-thinking now... Support the apps, and give us access to what we have paid for.
Edited by robw
I know it is not really solution, but you can put scenes to widgets so use scene to control VD. For example I have VD with button that turns on TV, stops music, dim lights for movie evening. I have write very simple scene that is manually started with RUN button and then it presses button on that VD.
@Sankotronic
Thank's! That sounds like a workaround I have to try!
