damo78 0
I am trying to call Fibaro REST APIs from either Lua script within a scene, or from a VD and I have struggled for hours without success. I think I've read nearly every post here and still no joy.
I have been able to run node.js calls to my HC2 so I know it is just my Lua code. This is my latest attempt from a scene, which has been as much progress as I've made in 4 hours.
This gets me the furthest (Note: I've changed the method and url combinations for these sets of tests also):
[DEBUG] Success: 401
[DEBUG] Failed: 401
I know this is an authorisation failure but i cannot find any documentation for how to include it. I've tried the
and various others.I think I've tried every combination of everybody's code snippets in one way or another. The documentation for this is a little lacking....
/emoticons/default_icon_confused.gif" alt=":-?" />My basic requirement:
To use the REST APIs because there seems to be much more [json] data available than using the Lua code alone (unless someone can suggest otherwise). Before I can get to using this data, I need to know some first principles on how to GET it (think I should be okay to json.decode and use after that), and POST/PUT it, primarily from a scene, but possibly using a VD too which I believe maybe different.
Your help, documents, post-pointers etc. would be sooooooo much appreciated. Thanks.
5 answers to this question
