Hello All,
I've got a problem with the Fibaro dimmer 2 in combination with dimmable led or power saving lamp. First, I've connected a normal bulb to my dimmer and I am able to dim the lights. Afterwards, I wanted to dim my power saving lamp (Philips Softtone 12W,). I've calibrated the Fibaro dimmer to match the new lamp. The lamp keeps blinking, even if I try to turn it off. The same thing happens with my Led lamp (spots). First I thought the problem was with the low power, so I bough a Fibaro bypass 2. The lamp doesn't blink anymore and I can turn both lamps on and off. But I can't dim these lamps, they keep the say light strength.
I thought I was able to dim my lamp, because I have a dimmable lamp. But I don't know why it is not working with these lamps, but still works with a normal light bulb. So I was hoping that someone could share their light on my problem. Or am I misinformed and are my lamps not dimmable?
Thanks in advance. Btw, I've a 2 wire system.
