Valdate string containing blanks
I have been using the API/Json to retrieve all my light devices. Now I would like to do some additional actions based on the condition of the device name. Eg "Hallway light"
I can't get a simple if statement to be functional when the string contains a blank. Removing the blank and it works perfectly.
How to solve this? If (devicename == 'Hallway Light") then
9 answers to this question
    Anyone?
    Can you debug the devicename like: fibaro:debug("---"..devicename.."---")
    If you can share your code then we can debug it.
    local HC2 = Net.FHttp("10.0.1.30",80);
    HC2:setBasicAuthentication("admin","xxxxxx")
    response ,status, errorCode = HC2:GET("/api/sections")
    sectionsTable = json.decode(response)
    response ,status, errorCode = HC2:GET("/api/rooms")
    roomsTable = json.decode(response)
    response ,status, errorCode = HC2:GET("/api/devices")
    devicesTable = json.decode(response)
    local groundfloor = tostring('Ground Floor')
    fibaro:debug(groundfloor)
    for loop1 = 1, #sectionsTable do
    section = sectionsTable[loop1].name
    fibaro:debug(section)
    if (section == groundfloor) then
    for loop2 = 1, #roomsTable do
    room = roomsTable[loop2].name
    if roomsTable[loop2].sectionID == sectionsTable[loop1].id then
    fibaro:debug(room)
    for loop3 = 1, #devicesTable do
    if (devicesTable[loop3].roomID == roomsTable[loop2].id and devicesTable[loop3].properties.isLight == 'true') then
    device = devicesTable[loop3].name
    deviceid = devicesTable[loop3].id
    fibaro:debug(device)
    -- fibaro:call(deviceid, "turnOff")
    My result is all the sections in the debug and if I change "Ground Floor" to "Begane grond" (that is how I named the Ground Floor), I see all lights of that section in the debug, so that is ok.
    I changed it a liitle bit, you don't need authentication if you running it on the same HC2, secondly (was working also without this change) I removed the tostring when defining the variable groundfloor
    What result do you get?
    Its still not working, i would like to see all devices as lights in this section/room... Its still not passing the first IF statement. Crazy!
    Can you paste the output of fibaro:debug(section). (just before the first if)
    Are you sure you spelled "Ground Floor" correctly, case sensitive?
    In debug i get the following using above code.
    [DEBUG] 17:29:58: Ground Floor
    [DEBUG] 17:29:58: First Floor
    [DEBUG] 17:29:58: Outdoor
    Removing the IF statement i get the following...
    [DEBUG] 17:31:38: Ground Floor
    [DEBUG] 17:31:38: Kitchen
    [DEBUG] 17:31:38: Kitchen Light
    [DEBUG] 17:31:38: Hallway
    [DEBUG] 17:31:38: Hallway light
    [DEBUG] 17:31:38: Hallway Closet
    [DEBUG] 17:31:38: Chair
    [DEBUG] 17:31:38: Livingroom
    [DEBUG] 17:31:38: Window Line Light
    [DEBUG] 17:31:38: Sofa Table
    [DEBUG] 17:31:38: Dining Table
    [DEBUG] 17:31:38: Stairs
    [DEBUG] 17:31:38: Window Light
    [DEBUG] 17:31:38: Laundry
    [DEBUG] 17:31:38: Toilet
    Is this all what you get (without the if)? I miss First Floor and Outdoor. If I remove the if I get every light returned of my house (section, room, light, light, room, light, light, section, room light, etc)
    Something very strange...
    You are correct, I get more wo the IF, I get all sections, all rooms and all lights. I just wanted to show its passing throw wo the if, despite the text string is the same.
