change globalvariable with php
let me first tell my idea. i want to get a push message with information about my expected travel time. i have raspberry pi with apache for my php scripts and geofency to trigger this scripts.
i have made a script that gets the travel time from google maps, the next thing is put it in a global variable of my HC2.
this last part doesn't work. i have the following php code:
does anyone have a idea to get this code working.
    I've found my problem.
    /emoticons/default_icon_redface.gif" alt=":oops:" /> i forgot a comma. in the httpheader array
    /emoticons/default_icon_confused.gif" alt=":-?" /> . this one works now:
    i'm using a rpi because multiple reasons. first i'm using geofency to trigger the php script, to access the script i need to portforward the rpi. i'm not sure if it is a good idea to portforward my HC2 to the outside world. so i'm using the rpi for safety.
    and i'm not satisfied with the stability of the HC2, i tried in the past to use Net.FHttp but after a while de vd stops working after a while. so i stopt trying.
    my code works perfect now. whe i leave my work, i get my travel time from work (with expected traffic). and my wife gets a push message: get the food ready in xx minutes.
       You can try the following (don't know if it is working:
    Question: why do you use a rpi for this and not from a scene?
