Hi Everyone,
I was trying to install a dual relay today using a 2 gang momentary switch. I noticed that when i turn the power back on, one of the switch is turned on (without pressing the switch) while the other is off. I have yet to pair the module to my home center 2.
Can i know if this behavior expected as i have not setup in home center 2? Can someone help to look at my wiring and let me know if i did it correctly?
Thanks!
What is that on your drawing??? Anyway L on dual relay module must be wired to live wire L. Did you even look at the instructions leaflet that came with dual relay?
    Thanks for trying to help. Of course I read the instructions.
    Yes, the L wires are connected to live. WAGO clamp is used to extend the live wires...
    Well, sorry but you didn't explain red color wires and live wires are usually brown and also missing incoming live wire on your drawing. Anyway your wiring is then done according to instructions so it is ok. By default it remembers status of relays before power cut so if it was triggered before power cut it will again close contacts after power is back on.
    thank you. i guess i will need to pair the module with my homecenter and it should work.
    Did you set parameter 14 and 15?
