HCL scene activation via binary sensor
Guest AxelS
Hi guys,
short question, is scene activation via binary sensor (parameter 14) available at HCL? I saw the option to trigger in block scene the scene activation ID, but unfortunately nothing happened?
I might to remember, that scene activation isn´t available for HCL ... True?
Thx & best
Axel
yes, it is possble on HCL. I do it. You first need to activate parameter 14 (1 - function on) in the device advanced settings of your binary sensor before you can use in the scene.
Guest AxelS
    Thanks for the info!
    best
    Axel
