Is it possible to make a block scene that turns a light on and off in the same scene ?
by using the delay function ?
Or do i have to go to the lua in order to do this and if so are there any examples ?
Edited by T.Konopka
Wrong category. Moved from Crowd's Solutions.
9 answers to this question
Yes, I'm guessing it's more to it then what your telling.
More info please
    id like to turn on some devices for a set time lets say 15 minutes in the morning and evening.   so one around 7 and 15 minutes after sunset again for 15 minutes.
    Not that much to it i suppose
    Something like this?
    Yes Will that work?
    Ive set it up for now not sure if the Device Will Go off
    On the blog posts i Read you Have to write a lua script to combine both
    Yes Will that work?
    Well, I have done it. Not that exact same thing, but should work fine mate.
    I guess it works
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> the lights are off now
    Ill test some more and then get back to you
    It works
    Good
