ash720 0
Hello All
I have searched, but not managed to find this question answered previously, apologies if it has already been covered.
I have a bathroom light currently operated by PIR so that it switches on at night without any user intervention. 2 problems, it comes on at full brightness and there is no override switch so you have to keep wafting your arms about if in for an extended stay.
I would like to use a Dimmer 2 to allow control of light levels via a momentary switch (fairly straightforward), but with a PIR switching on S2 to come on at low level at nighttime.
Checking through the parameters it seems that I can set both switches to be either momentary or toggle, not one to each. I assume the PIR output is simply a switched live.
Any suggestions on the best way to set this up?
