NodOn Zwave wall switch reliability
Guest minimax
Hi, I`ve bought NodOn zwave wall switch 4 button remote. I use direct association with duwi fslay to control ceiling light. But it is very buggy and in average ony 1 of 3 presses are correctly routed to the relay. I used duwi wall controller before and despite the paddle was jumping out every other press, it was responsive and 100% reliable. NodOn has a significant delay between pressing the button and the light turning on/off.
Does anybody have similar problem? The distance between the wall switch and the relay is 2 meters
Thanks,
Petr
I do not have problem with Nodon. Sometimes it just needs stronger press. I'm using it with RGBW module and 2x Dimmer 1 (FGD-211).
Try little bit stronger press. Maybe it needs just that.
My experience with the NodOn remotes are very good. I have bothe the Octan and the double paddle versions. Sometimes my pushes are not good and therefore no reaction, this regards the Octan. The double paddle are much easier to push correct.
Guest minimax
    So that is exactly same as my experience. It SOMETIMES needs a harder push. I would expect a wife-fiendly behaviour.
