Brain melt.......encode url - how to ?
I am leveraging a bridge to interact with my sonos systems
The command to invoke is simple....
but if I want to have more than one word i need to separate them with a %20 in the url ..like
Now if I drop the following url into a browser (note space between 'hi' and 'there')
It works !!!...
..but if i use it in a scene it doesn't
I had this working from a scene before so I asked the developer of the sonos bridge and he said ..
That's regular url encoding. Most browsers will convert that transparently when writing a URL, but if you invoke it from a script or similar, you need to do that, and always had to (unless the script url encode automatically).
the last part is the important bit.....so my question is how can I get the http request in the scene to invoke the url so I don't have to add the %20 as spaces
I tried a number of options but can only seem to find a way to encode headers or data but not the url
I am 99% sure I had this working but in a recent overzealous clean up of my code I must have deleted the sample code that worked for me.
Could anybody help ?
-Frank
9 answers to this question
try this function:
function urlencode(str)
  if (str) then
      str = string.gsub (str, "([^%w])",
      function (c) return string.format ("%%%02X", string.byte(c)) end)
  return str
    Thanks folks,
    I'll give them a go
    -F
    okay - must be missing something here
    looking to encode the string "the cat sat" to "the%20cat%20sat"
    Whats not right here ?
    and I'm getting the following output
    local message = "the cat sat on the mat"
    fibaro:debug("original message = " .. message)
    function urlencode(s)
    if (s) then
    s = string.gsub (s, "\n", "\r\n")
    s = string.gsub (s, "([^%w ])",
    s = string.gsub (s, " ", "+")
    return s
    test = urlencode(message)
    fibaro:debug("encoded message = " .. test)
    Thanks Remko
    I thought I could use the same variable after it's encoded but looks like you can't
    much appreciated
    -F
    of course you can, just do
    Yep, but then it was less clear what the issue was
    might have been my fat fingers
    thanks for the help
    -F
