Horstmann Controls HRT4 ASR-ZW
Hello
Since last update to version 4.090 I am unable to create any scenes that control these devices.
They work manually so can turn off and on no problem by device control but:
1. The Magic Scene now no longer shows these devices (whereas previous version did and was able to control it)
2. The Block Scene shows them, but no matter what you set it to it does not actually control the device.
I am now without hot water and heating controls as the HCL version 4.090 wont control them automatically?
Is there a trick I'm missing?
Previous version as said I was able to create a magic scene that turned them on and off by a timer control, but now magic scene don't show the devices for selection??
Wayne
Hello
Wayne
Did you try to re-include the device?
Did this the trick?  I have number 2:  2. The Block Scene shows them, but no matter what you set it to it does not actually control the device.
In desperation at the heating panel not working (which Fibaro seem not at all bothered! judging from their lack of response on the forum) I have resorted to creating scenes to control heating, and yes I had exactly the same problem, the scenes would not control the devices.
The only thing which seemed to work (although yet to test its operation when left to its own) was to change the setting in the red box after the device from 0 seconds to 10 seconds.
