Whats wrong in this scene?
Running it manualy using "play", works, seems to not trigger with clock?
The lights have beed shut of using monentary button.
Side question, how do I delete a unnasigned room ?.
6 answers to this question
Have you enabled "Start when Home Center 2 starts"?
    Yes I have
    Time based scenes that don't have any other triggers must have checked "Do not allow alarm to stop scene while alarm is running" if you don't want them to stop working. Even option sound like scenes will continue running after alarm is stopped that is not the case (Fibaro is this a bug?) so they have to be manually restarted or by autorun after rebooting system.
    Ok, thanks for your inpot, I'll tick thee alarm ting, reboot, and see what will happen
    Please, check this thread
    Do you encounter similar issue?
