Hello everybody,
I'm searching for a possibility to turn on the Fibaro Alarm Panel with one seperate device.
I have door- and window-sensors in the complete house and now i want to turn on the Alarm when leaving the house.
I know about the zipato rfid keypad. but my question to you out there: how do you use the Alarm Panel via device?
I'd like to have a seperate device at my wall beside the door, where i can turn on and off the Alarm Panel and get a direct Response via a Little led (e.g. green when Alarm turned off, red when Alarm turned on).
does anyone of you have such a Panel / device in use? or how do you turn on your Alarm Panel when leaving the house?
thank you for a response!
On below link you can find my setup and how I use it. Remember however that the zipato rfid keypad is not compatible with Fibaro HC / HCL.
You need to find another regular keypad which you can connect to the Fibaro universal binary sensor. Or, even better, connect it to RGBW controller which allow you to have direct response of alarm status (I send the status to my PLC Logo Siemens version 8 ).
