MultiSensor 6 Temperature calibration is not possible 4.090
Guest swissnet3000
Is that a problem of Fibaro or multi sensor manufacturer ?
If I change the value, I get ridiculous numbers.
Guest chaicka
    Parameter 201 is a 2 byte value in the following format:
    Our team has most probably found the issue with the device.
    Devices with software versions under 1.04 use a very unusual manner of setting parameters. One has to update the device. Newer software versions work fine (according to our team who tested the device). Check this link for updates
    Please, update the device accordingly to the manufacturer's manual. After updating, simply delete and re-include the device.
    Here you have a description of parameters
