Yet another script for sunrise and sunset and more....
Franz
NightAndDay is a LUA script to set two global variables at sunrise and sunset and at sunrise + a sunrise offset and at sunset + a sunset offset.
You can choose the name of the global variables to set.
Default are itIsNight and itIsNightOne.
You can define two different offset values (between -7200 and 7200 seconds) for both sunrise and sunset,
sunrisetime_offset and sunsettime_offset.
itIsNight will switch from 1 to 0 at sunrisetime and from 0 to 1 at sunsettime.
itIsNightOne will switch from 1 to 0 at sunrisetime+sunrisetime_offset and from 0 to 1 at sunsettime+sunsettime_offset.
At this link you can donwload the script (zip file) and the documentation (PDF):
