How to catch response from virtual device
I have a global cache itach flex sending commands to some items, these items can send a reponse back. Using the Global Cache itest software, I can see the reponse.
I want to be able to record the response in Home Center, and when the reponse is received, change the state of variable.
So, variable set to "No".
If response received, variale = Yes.
After "5 minutes" of variable = "Yes", set variable to "No".
Can this be done, and if so, can you provide a sample lua code for this?
Cheers,
