Problems with parameter settings
I am a Newby. Therefore please excuse if this question is a beginner mistake.
Up to now I used for my z-wave device the zway software. Now I upgraded my system with a HC2. During the installation of the HC2 I updated it to the Software version 4.090. Hope it was not a mistake.
The system themselbves runs proper, but I have some problems with the parameter settings. I have 2 remote controls, one a KFOB-C and ane a wall remote switch from POPP. The KFOB-C has no parameter template, the POPP has a template. But with both of the remotes I have the problem that I can't save the settings. What I did:
1st: I set the parameters and then I saved it with the floppy symbol. (see 1.jpg)
2nd: woke up the remote near the HC2.
On the event screen on the top of the HC2 screen I saw that the parameters are updated, but after the wake up of the remotes I got the information that these parameters do not exists. None of the parameters was stored. (see 2.jpg)
Did I made a mistake or is this a bug of the 4.090 version ?
Thats the inforome the event screen:
[13:29:18] ID 122: Set parameter 1, value = 0
[13:29:18] ID 122: Set parameter 2, value = 2
[13:29:18] ID 122: Set parameter 11, value = 2
[13:29:18] ID 122: Set parameter 12, value = 4
[13:29:18] ID 122: Set parameter 13, value = 4
[13:29:18] ID 122: Set parameter 14, value = 4
[13:29:18] ID 122: Set parameter 30, value = 1
[13:29:48] ID 122: No report was received for parameter 1. The device might not have this parameter.
[13:29:49] ID 122: No report was received for parameter 11. The device might not have this parameter.
[13:29:51] ID 122: No report was received for parameter 13. The device might not have this parameter.
But also the parameters 2,12,14 and 30 are not safed
4 answers to this question
Can you share the names and exact models of devices you use?
    Thanks for the reply.
    Here my modules.
    1.) KFOB-C remote control from POPP
    2.) Battery Wall Controller from POPP
    I have attached both manuals. Hope you can support me.
    I could identify the problem. It's the version 4.090 !
    What I did:
    - First a backupof my system
    - Then a downgrade to the 4.035 or 4.031. However.
    - Then I have excluded the modules with the parameter problems and then again included. Now I could set the parameters. It was not easy a some of the parameters escaped from time to time but finally I was successful.
    - Then I have updated to the 4.090 Version again. The mudules stayed configured as expexted.  Happy ..
    - Then I have  recovered my  backup  -->  and now the finally configured modules were not displayed in the modules. They are escaped.  Really unhappy ...
    But the modules are included in the z-wave network. What can I do that they are dispayed into the modules.
    I have already tested under "Configuration" the "Mesh network reconfiguration", but without success.
    Has someone an idea how to solve this problem?
    i,H
    as the version 4.090 do not run well I want to use a lower version. Is the 4.070 really stable?
    I have reset my HC2 and now I have the software version 4.031. How can I update now to the version 4.070 or 4.080. In the configuration chapter the update to 4.090 is offered only. And when I restart the HC2 in the management mode I can't chose a file as these buttons are grey, in the moment out of use. How do I get the lower version on my HC2?
