Items order for not admin users
   I would like to have the same order for different users.
The items order is well managed with admin user but is different for other user.
Only admin user can manage order for devices, scenes, ... .
For other users the interface order by id number and I can't modify.
The order is the same for web and mobile interface.
Is there a solution?
Best regards
Luca
PS: I use HC2 firmware 4.090
Guest chaicka
Best regards
Luca
I have several different user accounts which are used on iOS mobile devices. I am now able to move the sequence of devices in the Fibaro iOS app. I happen to just swap/arrange the sequence of some motion sensors and climate sensors around today on my iPhone 6s. Works fine. Just need to press and hold slightly and once the device bar shows slightly pop upwards, move it around (up or down) along the list.
Not sure if it stays in the order after exit and relaunch of app or not (this was the bug for many versions before current).
    I wrote to the support but also no true answer
