Tylö Sense Combi via Fibaro
Hello!
Is a possibility of external control sauna Tylo Sense Combi by Fibaro?
In the manual is info about control via low voltage (3V DC).
Thanks.
Edited by T.Konopka
Wrong catergory. Moved from Crowd's Solutions.
Yes. Its trivial to get it to work as a remote on/off switch it's a little more tricky to emulate an extra control panel.
    Do you mean about RGB modul?
    No I would not use an rgb module. I do not quite understand the scemantic may be obvious when looking at the physical thing but i think that you would need a dry contact "potential free" contact between 11 and 19. Maybe a fibaro or qubino relay?
    Edit: Strike that! Seems the remote on/off require some additional signalling. May be hackable but will require some extra electronics. Don't think you can easily do it with an rgb either. May be your best bet to connect to the modbus? communication line for the display. That ought to give you much more flexability. May be worth a try to ask tylö how that communication works or if they can provide a way to talk with the sauna.
    Edited by Joacim
