Can someone test it and post the experience. This is exciting.
RFID Reader (Zipato/BeNext/Wintop) is represented as 2 icons:
1. DoorLock - represents the state of RFID reader
2. BinarySwitch - allows to queue a turnOn action for Notification Sound (build-in beeper)
There are 2 possible ways for using RFID Reader.
You can either change device's state by TAG, or by built-in keypad.
QUICK GUIDE
Available actions for the device:
getUserCode(int userId)  // action will check userIdStatus for requested userId
setUserCode(int userId, string userIdStatus, string pinCode, string userName = "")  // action will set User Code for specific userId
setUserCodeDec(int userId, string userIdStatus, string pinCode, string userName = "")  // action will register TAG Code to specific user
getMaxUsers // action checks max supported users by the device, automaticcaly triggered during inclusion of the device
Useful properties:
secured(int) // 0 - status HOME; 255 - status AWAY
value(bool) // false - status HOME; true - status AWAY (mapped from property secured)
userCodes(array) // stores information about available users
First steps:
1. Include the device to Home Center 2
2. Select Controlled Device for BinarySwitch as "Other Device" using pop-up //OPTIONAL
Using TAGs
In order to use a TAG to change device state pairing it with the Reader is necessary.
Instruction in located below.
Step-by-step procedure:
1. Open Devices TAB
2. Click HOME or AWAY button in the device and place the TAG at the front of build-in keypad
3. In Log Window at the top of the interface, an information will appear about usage of an Unregistered Code with RFID Reader - save the code for next steps, it should look like this "[143,40,31,11,1,32,2,128,0,0]"
4. Using Lua or REST API queue check for userIdStatus for first or more users
example:
5. WakeUp the device manually by:
- changing state of tamper on the back of the unit
or by
- a Tag read (clicking AWAY/HOME and placing the TAG at the front of the keypad)
or by
- a code enter using a keypad (clicking AWAY/HOME and entering using the keypad) // any 4 to 10 digits confirmed by Enter button
6. Check property "userCodes" in API for RFID Reader or use a scene to do it.
example:
After running this scene in debug window there will log like below:
[DEBUG] 12:07:01: [{"name":"","id":0,"status":"Available"},{"name":"","id":1,"status":"Available"},{"name":"","id":2,"status":"Available" ........
Supported userIdStatuses:
Available  //this userId could be used
Occupied //this userId is already occupied
ReservedByAdministrator // reserved
StatusNotAvailable // not available
7. Use setUserCodeDec action to register TAG in the device to desired user, userId with status "Available" must be used. Also userId=0 cannot be used. As a PinCode use Code Returned by the device as Unregistered when TAG was used before (step 3 of this guide).
UserIdStatus "Occupied" must be used in action to set a new PinCode for user!
example:
8. WakeUp the device manually by:
or by
or by
From now on every time the TAG will be used with the RFID Reader to change status (HOME -> AWAY or AWAY -> HOME) device in interface will change state and in the Log Window a information about using the device by specific user will be visible.
Using build-in keypad
In order to use a Keypad to change device state setting a pinCode for specific user is necessary.
Below are instructions how to do it.
1. Using Lua or REST API queue check for userIdStatus for first or more users
example:
2. WakeUp the device manually by:
or by
or by
3. Check property "userCodes" in API for RFID Reader or use a scene to do it.
example:
After running this scene in debug window there will be something like this:
[DEBUG] 12:07:01: [{"name":"","id":0,"status":"Available"},{"name":"","id":1,"status":"Occupied"},{"name":"","id":2,"status":"Available" ........
StatusNotAvailable // not availaable
4. Use setUserCode action to set a PinCode to desired user, userId with status "Available" must be used. As a PinCode use 4-10 random digits.
To set a new PinCode to user as userIdStatus "Occupied" must be used in action!
example:
// userId=2 was used there because userId=1 is Occupied by TAG
or by
or by
From now on every time this code will be used with RFID Reader (Home -> Away or Away -> Home) device in interface will change state and in the Log Window a information about using the device by specific user will be visible.
Clearing specific user pinCode
To clear assigned PinCode for specific userId use action setUserCode with userIdStatus=Available and random pinCode (4-10 digits).
example:
KNOWN ISSUES:
- zero/zeros cannot be the first sign/signs in PinCode string (for example PinCode 0014823 will be interpeted as 14823!)
There should be a use guide available before stable release, as far as I know Support team is working on it.
lol i am sorry but that is hilarious!... heard of the carrot and the donkey?
can you not just give users an idea on how to use it? pretty sure it would take a user who knows how 'bugzilla' less than 2 mins to populate SOMETHING?
Edited by Supernode
Yes... We need some infos about this. ^^
i tried to work it out... using bugzilla comments as a guide but no joy! sorry but someone else can take over as it will be months before you get docs!
the same for me
I will add here simple "quick guide" probably today, official guide will be released before stable release as I mentioned before
Nice
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Thank you. Seems to be a good update ^^
It works. Nice work guys (Fibaro)!
Edited by clausdk
much appreciated these little things are what make the difference! forget impressing us with glamorous devices just butter us up with little nuggets!
what exactly is this? i see nothing in api etc... or even the status updates in gui!
"name_arg_is_optional"
This is a value stored in Z-Wave internal database only, not used in the system right now.
Will this change so status in GUI shows the allocated name?
Edited by Supernode
This feature will eventually come - for now we prepared as much support for those devices as it was possible at the time - without other major changes/rework in system.
PS
Instruction in this topic (the part about "Using build-in keypad") will also work with Doorlocks which supports User Codes.
Cool
any quick tip on lua
if usercode 1 unlocked then <foo>
this would be great if you have any idea?
I have created a Predefined Variable in the Variables Panel "HomeMode" with 4 values of "Home", "Away", "Night" & "Vacation"
I have used the following code to set the HomeMode Variable
114 is my keypad ID
114 value
%% properties
%% events
%% globals
-- Script to check status of Lock / Unlock of Keypad by Brent Brown
if tonumber(fibaro:getValue(114, "value")) == 1 then
  fibaro:setGlobal("HomeMode", "Away")
  else
  fibaro:setGlobal("HomeMode", "Home")
PS
confirmed, it works with YALE YDM3168
well done!
Specific user is the aim... Me armed alarm or wife armed etc...
There are no infos about in the api. So I think it doesn't work at the moment
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> But it would be a nice feature...
