mysterious behaviour of my alarm panel
I have a problem with my Fibaro alarm panel respectively with a scene.
I use 4 different remote controls to activate or to deactivate my motion detectors (from Fibaro). Via a scene I can activate and deactivate it.
But what happens is
a) if I press the button to activate the the motion detectors sometimes it runs, sometimes only one of my 2 motion detectors is activated and sometimes happens nothing.
b) In the most of my tests I could deactivate the detectors only with this remote which I used for the activating.
c) Within the scene I use also a lamp which indicates me that the alarn is on or off. Sometimes, when I try to activate the alarm, I see that the lamp turns on, but only for a part of a second, then it turns off again
I have attached some screens with the scenes I used.
Can someone find a mistake or can explain what happens here. I tried also to use a delay in the scene, but also this has no influence on the crazy behavoir.
    Has really noone an idea whar happens here. I have this nice alarm system in my HC2 but can't use it.
    today I could solve the problem. The problem was to use all remote controls in one scene.
    If I press the button on remote A or remote B or remote C or remote D
    Then .....
    Now I wrote for each remote an own scene and it runs. It's not nice and I have a lot of scenes but for the moment it's ok. But I do not really understand why I can't use all the remotes in one scene.
    Did someon has the same or a similar experience?
