lolocaledo65 0
Hi all,
I'm new on this forum.
I use a Dimmer 2 with one momentary physical switch and one Nodon remote switch.
all works fine but dimming control is very difficult with Nodon switch.
With physical switch, I can adjust easily the light, hold the switch a long time and adjust low intensity.
But with Nodon switch, adjust intensity is very difficult. If I hold the switch more than 0,5s, the light go off. Impossible to adjust to the minimum intensity.
Is there a parameter to modify this behavior ?
Thank you for your help
