Gaaroriep 2
Hello everyone,
Last year, i decided to enter the home automation world. after looking at all the option, i decided to go with fibaro.
I purchased a HC2, a couple door sensor, motion sensor,light switch, a yale door lock and a few cameras.
I tought i could give this a try, set everything up, play with it a little, learn lua and add more device overtime. After initial setup, i add problem with camera not being show most of the time, and door lock not working half of the time.after a few weeks of scratching my head, i gave up and let it on sit on my desk. I tought the system might not be mature enough and i should wait until there been more upgrade. A year have passed and i tought i might give it another try.
I tried to add my camera again but did not been able to make it work. I'm using foscam and amcrest camera. I have the API data for them, the http link work in a browser but not in the HC2.
The yale door lock is recognize but won't respond to any command.
Is there something i could try to make it work? i try delete and re-add the devices with no luck.
Any help would be very appriciated
Thank you
David
5 answers to this question
