Ole 14
Hi all!
I have a "robot" lawnmower and sometimes it gets stuck out on the lawn. When I am away I have no way of knowing so I thought I could get my Home Center to tell me, if I connect the charger for it to a Fibaro Wall Plug, whether or not it connects to the charger, which it should do a few times a week. I am not familiar with Lua code and I can't see a way to do this with a block scene. What I would like is for Home Center to tell me when the lawnmower starts charging. When in idle it uses about 7.5 W and when charging a little over 50 W. I made a simple block scene that sent a push notification when consumption was over 50 W, but then of course it kept sending notifications as long as the consumption was over 50 W so that doesn't work. So I thought I might need a lua script that sends one push notification when consumption is over 50 W and then waits until power consumption is down again before checking for consumption above 50 W.
Can someone lua savvy write me a script that could do this?
4 answers to this question
