Yale door lock not responding,
Hello all,
I have a yale door lock.
The device always appead as dead, and battery as low. I deleted, change battery and re-add it but it appeared as having no templates. After a few deleted and re-add, it finally installed with template.
But the device still not respond and appear as dead.
Tried to wake up (using the add/remove option in menu as it don't have a physical button) but it didn't work either.
Any idea on what i should try?
Thankyou
David
    I suppose you added it in secure mode and had the HC really close while including?
    No i did not...
    /emoticons/default_icon_confused.gif" alt=":-?" />
    Since it was added i tought i didn't need to do that.
    Just tried and it worked!!
    Edited by Gariep
