I have adoor sensor that doeasn't work anymore.
So i wanted to delete and readd it but i'm unable to delete it.
I tried to reset it. i get the led blinking 2 times but still not been able to delete it.
Anyone has as trick or is there something i'm not doing correctly?
Thank you
David
this is a bug in 4.090, I've got a lot of ghost devices I can't delete. Hope the next release will solve this problem.
cheers
emiel
    Thanks for the info,
    I finally been able to delete it ut i'm still unable to add it again...
    will wait till the next update
    Be sure that you reset sensor properly by the instruction given on leaflet that came with it in the box, and when adding make sure that is not more than a meter or two away from HC and inclusion should go without any problems.
    up until 4.090 deleting modules by just clicking the X was enough, from 4.090 this doesn't work anymore, and modules even start 'ghosting', sort of multiplying themselves without me doing anything.
