Fire Alarm scene/dashboard
Hi all,
I am new to Fibaro but pretty competent with technology (being a software engineer), but I am struggling to find how I get to configure the Fire Alarm as per the promotional material on the Fibaro site for the Smoke Sensor, particularly the video.
It looks like this is the alarm panel, but in the alarm panel there only seems to be options for the intruder alarm. At the moment I only have HC2, smoke sensor and motion sensor (door sensors on the way), so maybe not enough "kit" to be able to fully use these features but I was hoping I could have some way to get a control panel like that on the image above.
Are there any guides out there? I'm happy writing LUA code but I find it hard to find any real information (other than helpful users here) on LUA and its features in HC2 and how they integrate with these panels. I can certainly write LUA code that will turn on my lights, push notify me that something is wrong, but will that automatically kick in this panel above?
15 answers to this question
Jep, alarm panel is only for intruder alarm and for fire alarm or flood alarm there is no such panel. I didn't even like how intruder alarm panel works so I did all of this alarms with LUA scenes. Here is example of Fire Alarm scene:
Similar code can be used for flood alarm. For intruder alarm there is more scenes but two are essential, one for arming sensor and one for disarming sensors. The rest is just configuring what will be armed depending on situation like going away for one afternoon, or going away for holidays or just going to sleep. Also we have two small dogs and if they stay at home then room in which they will wait for us motion sensor is not armed etc, etc.
    Thanks for the info. Very disappointed in Fibaro for blatantly mis-selling that feature in their literature! If there werent so many other things that I want to do with the HC2 I think I could return it on the basis of false advertising!
    Anyway, had a feeling that I would have to do it via Lua. Good job they have such good people like you in the community that have examples of Lua code people can use! I'll give that a go tomorrow night as I'm out tonight. Got the ZipaBox RFID reader to play with too
    I have used this Fire Alarm Config and have set 3 Sirens to go off when triggered.. question is.. I want to flash my dimmer2 and possible act other lights on this being active.. but I am a little confused about "Alarm states" for SMOKE CO2 etc etc.. if I don't use Fibaro Alarm and run my own script for arming and disarming, including this FIRE Scene.. how can I send commands to other devices like lights to behave in alarm state? or should I just script the turnon, turnoff in this script? the whole "associations" "Broadcasting frames" thing is a bit of a mystery to me!
    it gives me an error on the following line:
    local smokeID      = tonumber(trigger('deviceID'));
    error = [DEBUG] 15:57:54: line 16: attempt to call local 'trigger' (a table value)
    How can i resolve this error. i have 1 smoke detector at the moment
    Did you start this scene manually? If that is the case you don't have the field "deviceID" in the array called trigger.
    This scene is only working if triggered by a device.
    If you want to test it you will have to override this (just put any number instead of "trigger['deviceID']").
    no automatically as it suppose to do, otherwise not been trigger from deviceID
    local smokeID      = 211;
    --local smokeID      = tonumber(trigger('deviceID'));
    then no error. but with the second line an error
    you wrote
    local smokeID      = tonumber(trigger [ 'deviceID' ] );
    error: [DEBUG] 12:07:36: line 115: attempt to concatenate local 'deviceId' (a nil value)
    I think needs to be, but still an error
    local smokeID      = tonumber(trigger ( 'deviceID' ));
    error: [DEBUG] 12:06:25: line 17: attempt to call local 'trigger' (a table value)
    what do you think what i am doing wrong
    This is how I start the scene: gives an error at this line:
    local smokeID      = tonumber(trigger['deviceID']);
    %% properties
    211 value
    %% globals
    -- FIRE ALARM --
    -- This scene will be activated by all smoke sensors that have ID value under %% properties and then it will activate siren
    -- and send notification to admin and all users added in code.
    -- setup some local variables
    local trigger      = fibaro:getSourceTrigger();
    local smoke        = tonumber(fibaro:getValue(smokeID, "value"));
    local pushMessage  = "WARNING! FIRE ALARM IS ACTIVATED!"
    local emailMessage = "Fire detected by the following sensor:\n"
    local imgUrl       = ""
    local deBug        = true;
    local sirenID      = 100; -- <-- NOTE!! change this ID with your siren ID!!!
    local delay        = 20; --Siren off delay after sec.
    Sorry, I don't understand what you mean.
    looking at this code:
    I got an error on this line:
    [DEBUG] 14:35:30: line 115: attempt to concatenate local 'deviceId' (a nil value
    but maybe its another problem.
    What can it be?
    What can it be?
    You can get this error if you run scene manually by pressing RUN button or call this scene by another scene or VD. I'm working hard on this and several other scenes and I will do my best to post them before Christmas!!!
    This I wrote yesterday already... ;)
    @Alex You are right, you really did write that yesterday, but @samuel asked again! And again answer is the same ;)
    Hi
    and everyone.
    I don't have any siren, can I just replace the siren ID with any device ID that I want to trigger (e.g. a turning on lights)?
    And how do I best test it?
    13 hours ago, texan said:
    Hi
    and everyone.
    Hi @texan,
    Yes you can activate any device instead of siren or change code to suit your needs. Check latest version of the scene here:
    x
    Edited by MarcinL
    Pomyłka
