Guest FredrikKarlsson
I've added a couple of routing nodes to my network, and had to move one node in the middle of the network. Having a bit of a problem getting reports now from one far off node.
Will the HC2 fix the network eventually by itself, or should I do a network reconfigure manually? What would be the best strategy for reconfiguring the node connections (work my way out to the node, or just reconfigure the one node that is having problems, although there are now new nearby nodes?
