How to move from HCL to HC2
Is there a procedure to move from hcl to hc2, which could avoid me to reconfigure each sensor/scene?
I see in configuration-zwave network a function called controller transfer, which seems to be what I need.
Thanks for you support
Giovanni
4 answers to this question
    Giovanni
    Any feedback Fibaro support?
    I would be willing to buy a new hc2 but I hope you took into consideration a way to make easy to migrate from hcl to hc2!
    This is the thread you are looking for
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
    Thanks!
    Unluckly, the answer was not the one I expected....in my opinion it should be a priority for Fibaro to have their users to move from Hcl to hc2...but the fact not to have a procedure to speed up the transfer for sure doesn't facilitate.
    I also suggest to delete functions like "controller transfer" whose scope is unknown.
    Giovanni
    Thanks!
    Giovanni
    Thank you for your suggestions!
    Please, refer to the topic I sent you the link to.
    Closing this topic.
