Hello all
I would like to know if i can replace the CR123 battery with a rechargeable CR123A battery 3.7V as they are at 4.2V at full charge will it blown the module?
I know some device can't handle it, i already blown a flashlight with these, don't want to blown a module
Thank you
David
Edited by Gariep
I use rechargeable batteries in my motion detectors. No problems at all.
BTW what capacity do you get out of those LiIons? I bought some from a "cheap seller", advertised as 1000 mAh and expected them to be around 500. I got 250
/emoticons/default_icon_smile.gif" alt=":-)" /> :-)
/emoticons/default_icon_smile.gif" alt=":-)" /> So expect to change batteries 4 to 6 times faster than when using "primary lithium cells".
I use these for test purposes only
BTW it didn't blow my MultiSensor 6 from Aeotec.
Guest chaicka
Good info...Just what I was looking for. Next cycle, I put two of them in and see how it turns out.
