Variable
Hello. I hope someone can help me, or has a tip for me.I am looking for a script with which I can check the status of a variable, and then depending on the state, a scene can be run.
The script will start each day at 7:00 am - and when the variable "Work" is at "breakfast", Scene xyz perform .Stands the variable on " late " ,then start Scene abc ...
I have already tried, it get in Lua but not out .In block scenes runs it course, only I need it then too many ..
I would be very grateful for a tip or help ... Regards
6 answers to this question
    Hmm, no one ?
    Can you post what you've got? I'm a complete Lua beginner but might be able to patch something together
    What do you want as a trigger?
    I created an example of a lua script, which is triggered by a change of the variable. Is this what you want?
    You can play with the between time when it needs to execute the scene.
    It's a quick example because I have limited time at this moment, but if you need something else, please let me know.
    Edited by Cafun
    Hello. Thanks for reply. Yes, I think that's the way I need it. Will it later to try again and then report me. Thank you very much
    It is not working so...
    Debug : in line 7 ...
    Sorry for my late reply. I now follow this topic and get an email when a new post is placed.
    Ok, so you can remove the "local startSource = fibaro:getSourceTrigger();" line, however he's running fine on my hc2.
    Can you try it again please. It should be working. Maybe copy and paste it again.
    Edited by Cafun
