Light do not appear in mobile app
Gaaroriep
I have 3 dimmer installed but in the mobile app, i can't see them in light icon, it say no device of this type. Instead, i found them under "appareils" in french  version may be "device" in english?  is there a reason for this? The are identified as light on web UI
Edited by Gariep
Did you mean you set "Lightning" in "Controlled Device" in the advanced parameters of the devices? If here is specified "other device" then you won't see them in the light section of the mobile app.
Make sure you set "Lightning" or "Wall lamp" or other lamps in "Controlled Device" in the advanced parameters of the devices.
