Table Insert LUA
Hi ,
I have a problem with a piece of LUA code and i'd like to ask for help from the LUA gurus
Basically what i'm trying to achieve is store some values in an array like array = {January = 1, February = 2} . The number after the equal sign is taken from a global variable that changes as a water meter runs every 100 liters. I've got the code that reads the meter and increments the global variable by 0.1 sorted out.
The scene has as trigger the UBS value that reads the meter - every time the UBS is 1 it increments the global variable by 0.1
So far so good.
Storing the data is the problem: I'd like to store the data in an array like above.  The problem is that every time the scene restarts the array will be empty again. I want it to be populated with each month and the value.
Also, the scene is started multiple times per day so the code should check if that month is already in the array and if it is just rewrite the value, otherwise insert the month and the value in the array.
I hope i was clear enough
My code which at this point sucks
Edited by Momos
16 answers to this question
As I understand you want to store water meter value per month, right?
May I suggest to use json table as global variable or virtual device with labels.
Edited by cag014
As @cag014 said: Use a global variable to store the months table.
Not tested.... Hope I understood what you were after
EDIT: fixed the month error - cheers @cag014
Edited by seiq
    Doesnt seem to work.  Produces a debug line:
     [DEBUG] 22:[DEBUG] 22:17:31: month 27.6
    I don't think i understood the suggestion thou:
    Create a global variable lets say WaterMeter and in first value field put a table like {"January","February","March"."April","May","June","July","August","September","October","November","December"} ?
     2
    Edited by Momos
    Please try it now (create MonthsData as global predefined variable)
    In general this code creates the table on the fly for every month.
    Have tested and it works... (for example I have set the WaterFlow value to 1)
    [DEBUG] 23:47:59: September 1
    Edited by cag014
    seems to be doing something : [DEBUG] 23:58:53: September 28
    How should the variable MonthsData look like ?
    And what happens next month when monthsData = {} will reset all the table? will it still keep the previous month ?
    Sorry if the questions are dumb but i'm tired and missing the obvious most likely
    It looks like json table stored as string.
    Add debug after setting global
    fibaro:setGlobal('MonthsData', json.encode(monthsData))
    fibaro:debug(fibaro:getGlobalValue('MonthsData'))
    next month the code will add October to the table, so you will be able to see September and October (and so on...)
    Just for an example set month to let say January and see how it works. Don't forget to remove the line after test.
    local month = os.date("%B") -- month name
    local monthsData
    month = "January"
    Note:
    The monthsData = {} resets the table only in case the table not exists. (For example you did full recovery to HC2)
    Edited by cag014
    [DEBUG] 00:57:58: nil
    [DEBUG] 00:57:58: September 29
    with the debug line added.
    Did you create MonthsData global predefined variable?
    In Variables panel
    Edited by cag014
    Thanks for fixing the error in the code @cag014. Had it that way first... no idea why I changed it
    Note:
    Has become a habit to put json.decode() in a catch block (pcall or xpcall) when retrieving a global variable. Globals have been known to corrupt or clear themselves which can cause your script to crash. Not so bad in a triggered scene but sucks for the main loop of a virtual device.
    In Variables panel
    Not a global 'predefined' variable. Just a normal variable in the 'Variables Panel' on your HC2 (ie: the top one) Can't write custom values or a json string to a global predefined variable. I'm pretty sure you didn't mean it this way @cag014
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I've seen the two different types get mixed up a bit on these forums.
    seiq, I tested and even use predefined global variable for storing tables and it is working. Just need to make global with one value with any name and I usually name it Table. Value 2 I delete after saving since it can't be removed during definition. Also it is better to use predefined global variable to store tables because it doesn't get corrupted as normal variable when saving in global variable panel.
    Edited by Sankotronic
    Wow. I'd never actually tried setting a predefined global with a custom string. Can't believe that actually works! haha I was always under the impression the predefined variables were to provide a level of data validation...guess not! Surely that's not intended functionality and just another Fibaro quirk?
    One thing I did notice is the predefined variable doesn't show the custom value in the Variables Panel. When I click the save button, the predefined variable with the custom value is overwritten with what is displayed in the drop down list. So it still gets 'corrupted'...
    Edited by seiq
    What I have found that, the global variables are good for numbers and predefined variable work excellent with strings.
    Yeah I see the
     site does suggest standard (global) variables are for storing numbers. It also suggests that predefined variables are for storing words (strings) but are supposed to "limit the content of the variables" to a value in the drop down box. So it's a bug that's being exploited to store custom strings. Same goes for storing strings in a standard global which is designed for storing numbers. Personally I've never had a problem (apart from the hitting the save button in the Variables Panel) storing json strings in standard global variables... yet.
    IMHO, functionality with this type of design by Fibaro would be:
    - standard globals for storing custom values (strings, integers, booleans [, tables])
    - predefined globals for exactly that; storing values from a predefined list. Most likely a string as they can easily be converted to a number.
    Additionally:
    - A value could be returned from fibaro:setGlobal(). TRUE if the value was successfully updated, NIL on failure. Bit of validation never hurt anyone right?
    - The little text box for standard globals could be widened and set read only with an 'edit' button column added (next to delete like the predefined variables have now) to modify and save the value manually if required.
    But what Fibaro really need to do first is fix the problem causing the standard globals getting corrupted and set to NaN and update their !@#$%^* documentation so we know how they intend things to work instead of guessing all the time. (Or vice versa; ensure the system operates as it's currently documented
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> ) But I digress...
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
    Absolutely right and well described.
    Let's see what Fibaro has to say about....
    Yeah I see the
    Additionally:
    I totally agree with you!
