How to automatically reconnect to dead nodes
I have a Fibaro 2x relay which has been disconnected a few times (as I was turning off the fuse in order to do some installation), and noticed after a while that HC2 stopped sending commands, because the relay was now marked as dead. Is there any way to make HC2 periodically try to reconnect?
Guest chaicka
It does by default for all wire-powered devices. It doesn't once it is marked as dead and require manual intervention (wake up the device).
