Guest FredrikKarlsson
I am very confused by the functioning and documentation of "startLevelIncrease" that was made available a while ago.
It is not documented, I think, outside of the release notes for the release, but the description there was:
Ok, so I assume that devices with this call available in the interface when making a Lua scene will work for this. I also assume, since the documentation is a bit vague here, that the first optional parameter gives a time in milliseconds (usually the case) in which the change should have occurred, and a starting level.
So, this code should dim up a light from 0 in 30 seconds then:
But it does not. It dims in just about one second, and it does not matter att all what you specify in the third parameter.
Trying it with a TKB plug in dimmer, which makes the call available in the Fibaro lua scene editor (so I guess it should work?)
4 answers to this question
