change variable when pressing button in VD
Guest samuelboerhoop
change variable when pressing button in VD, how to if the button input is string and not lua ?
I put this code in the mainloop from a VD
-- change variable Fan_Speed when I is pressed
if fibaro:call(104, "pressButton", "4") then
  fibaro:setGlobal("Fan_Speed", "I");
  fibaro:debug("Fan Speed II");
I am not able to put this string in the button "I"
because the button is using string code, what controls the fan speed of IP to IR
I am using already a variable, but somehow need to change the variable when button I, II, III and 0 are pressed.
Any suggestions?
