muc 1
I found a VD with a button's code:
-- SYNCHRONIZATION TIME CONFIGURATION ----
ntpServer = "..."
local HC2 = Net.FHttp("127.0.0.1", 11111);
-- get current location settings
result ,status2, errorCode2 = HC2:GET("/api/settings/location");
--- checking
if (tonumber(status2)==200) then
response = json.decode(result);
response.ntpServer = ntpServer;
response.ntp = true;
-- set with new settings
local payload = json.encode(response);
local response, status, errorCode = HC2:PUT("/api/settings/location", payload);
and the main loop's code:
local syncTime = "03:03";
local currentTime = os.date("%H:%M");
if (currentTime == syncTime)
then
fibaro:call(id, "pressButton", ...);
fibaro:sleep(60000);
Can this (HC2=..., HC2:GET, HC2:PUT) be translated into a code which runs in a scene ?
(function xy() instead of button's code and setTimeout(.., xy) instead of main loop)
Thanks!
6 answers to this question
