Hey,
I am trying to synchronize all 4 dimmer out of RGBW module. My situation:
I have 4 white led strips connected to separated output of RGBW module. RGBW module is in input/output mode so I have basically 4 dimmers available.
Now, I want to synchronize all 4 dimmers together (so if I turn the light on, all goes on, if I dimm it, all dimms)...
To explain the situation better, I had to connect one long white led strip to 4 outputs because of 3A limit. I could not connect it to one output as it would be over 3A / channel. I would like to use it as one strip so associate them together and hide the 3 others. But the associaton does not seems to work between R and G and B and W output.
Anyone has any sollution for that? Thanks
Association works only between separate modules, device cannot control itself thru associations.
I think a scene is the only way to achieve this
    Can you give me idea for scene (it can be in LUA no problem) how to sync it? I mean there is no problem to turn ON/OFF, but sync the intensity is tricky for me.
