Gaaroriep 2
Hello all
I'm trying to use Lili,
I can use lili to turn on or off device but when i try to use it for scene activation it doesn't work.
She doesn't recognize the command even if i'm using the same word i was using for the device.
Off course i ad previously remove the command for the device and then reload lili database
Please note that i am using french language
Thank you
Edit: can we use the microphone port on the HC2 to use Lili? i tried with no luck
Edited by Gariep1 answer to this question
