os.execute nil ?
i'm totally new to lua, what i'm trying to do is to write the power value (FGP111 Plug) to a influxdb using curl/post.
what i get is that the output window tells me that os.execute is a nil value (non-existant ?)
if that is the case how else can i achieve this behaviour ?
(Homecenter 2, 4.090)
Any help is appreciated!
Thank you in advance
SOURCE:
%% properties
17 power
%% events
%% globals
local power = fibaro:getValue(17, "power")
if ((tonumber(fibaro:getValue(17, "power")) > 1 ) or startSource["type"] == "other")
then
  runcommand = 'curl -i -XPOST \"
--data-binary mischer,host=server02 value='.. power ..''
  print(runcommand)
  os.execute(runcommand)
OUTPUT:
[DEBUG] 08:51:08: curl -i -XPOST "
--data-binary mischer,host=server02 value=1.3
[DEBUG] 08:51:08: line 15: attempt to call field 'execute' (a nil value)
there are LUA restrictions (made by Fibaro, below the list) on HC2 (since 1.5yrs or so), so imporve security:
    fair enough, but how do i perform the post now ?
    with e.g. (from Scene) net.HTTPClient, check
