I'm having trouble with the new FGS-212 Relay Switch, when used with 2 room switches.
The switches don't work as you'd expect, when wired using the scheme in the manual. has anyone else had this problem, my electrician is struggling.
I can control the light from my PC or phone but not from the second switch.
Are you sure that the Relay Switch has been properly installed by your electrician?
