api.put question
I want to use api.get/put in a scene to change the parameters of my BeNext dimmer (without template).
reading parameters works, then change e.g. the value of 3rd parameter:
param= api.get("/devices/"..idDev).properties.parameters
if param ~= nil then
  for j= 1, #param do
    print(param[j].value)
  param[3].value= 77
but I don't know how to write the changed parameters:
???   api.put("/devices/"..idDev.."/properties/parameters", param)   ???
anybody knows the right command?
PS: is it necessary to change .lastSetValue and .lastReportedValue, too ?
Edited by muc
    Hooray! This really works:
    (I want to change "Dimming Speed" to newValue)
    idDev= dimmer's id
    idDimmSpeed= 7   --  id of parameter "Dimming Speed" by manual
      for j= 1, #param do
        local p= param[j]
        if p.id == idDimmSpeed then
          paramNrDimmSpeed= j  --  parameter's number in HC2
          break
      p= param[paramNrDimmSpeed]
      p.value= newValue
      p.lastReportedValue= newValue
      p.lastSetValue= newValue
      x= {}
      x.id= idDev
      x.properties= {}
      x.properties.parameters= param
      api.put("/devices/"..idDev, x)
    remaining question: is there any feedback of api.put possible ?
