Hi forum,
does anyone knows is it compatible with Fibaro HCL? Also, how can I configure it to has floor overheating protection with external temperature probe. Diagram is in user manual, but configuration is not clear for me.
Thank you!
Guest FredrikKarlsson
Sorry, but you need to hire someone to do the installation then. That is maybe not the most complicated wiring I've seen, and if that is then not clear to you, perhaps you should let someone that understands how it should be connected do it.
I am sure you will  be able to control it once it is installed. Don't know about templates though.
    Read my question again. I referend myself just to diagram and asking about software!
    Also, my first question is about compatibility with HCL.
    Any news about compatibility?
    I did not find anything about MH7 in change logs for any updates. About compactibility, please ask Fibaro support: [email protected]
    For what i can tell
    is compatible. I tested it personaly.
    For what i can tell
    This is excellent information. Thanks a lot.
    I will send them an email and ask for MH7.
    If anyone have any information, please share it.
    I have MH7 and MH8 . And I tested MH8 :)) . Is working .
    I didn't installed on an existing heating . Just put him at 220 V .
    Every command on him is working in Fibaro (is changing the value in interface) .
    P.S: I think if MH8 is working , MH7 will work too :D .
    Cheers.
