Horstmann HRT4 ASR-ZW script on/off fails
Hi community,
I installed this summer the horstmann HRT4 ASR-ZW to control my central heating and did some time scripting turning it on/off.
Only it doesn't work, I used this magic Scene (image number 1)
Only at 5:45 nothing happens.  When I convert the script to LUA this is the result:
%% autostart
%% properties
%% events
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
if (
 ( ((currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "05:45") )
then
setTimeout(tempFunc, 60*1000)
if (sourceTrigger["type"] == "autostart") then
tempFunc()
else
if (
then
Also nothing between then and end.
How can I switch this device on/off?  Using the button works fine. (image number 2)
Help is much appreciated!
Edited by barend121
4 answers to this question
    Up :-) does anyone uses a script to manipulate the horstmann relais? And can share the LUA script?
    In your case the following code is to turn on the CV switch:
    Change it to "0" to turn it off.
    What is your whole script? How does it know to turn the heating off?
    thanks a lot! will test it this weekend.
    The script is time based, when one of the rooms is scheduled for heating it turns on. when a extra heating moment is needed it can be overrided.
    It's time based, but what if the room is already at a comfortable temperature? Then it keeps heating?
