Simple LUA for those who know LUA
Like the title says, it should be a simple LUA question, but the answer eludes novices like me :(
I have in a scene a generated value which is a number with decimals.  I need a function to round up that number to the next multiple of 15.
For example if the generated number is 3.56 then it should round it up to 15; if the number is 17.87 it should round it up to 30 etc
Can this be done or am i dreaming ?
Thank you
Guest FredrikKarlsson
This is more of a maths / CS question than one related to Lua,
But, here goes:
Now, you can use your function to bin your data the way you wanted it:
Hope this helps.
(For other cases, please have a look at the Lua maths library
Fredrik
    works :) thank you
