netatmo welcome - local cam finder
it is possible to use the jpg-stream of the netatmo welcome in your own lan and without the netatmo api. I've written a scene to detect the correct url for the camera settings of the HC2 over the netatmo api. (See screens)
Somebody interested? It is a first beta version because the url could change from times to times. At the moment I don't know and we have to test it.
Greetings :)
Edited by boomx
I have a Netatmo Presence, and i tried to run the script in HC2 (4.110). I have created an empty app at the Netatmo website to get the client ID and secret key. I have created the scene with these credentials and the login/pass. The scene/script runs, but it stops at below message, and doesn’t output the IP and stream url.
 [DEBUG] 10:10:33: netatmo welcome cam finder v1.0b
 [DEBUG] 10:10:33: Debug: english
 [DEBUG] 10:10:34: API-Call was done.
Am i missing a step?
On 23-1-2017 at 1:59 PM, HomeSystem.sk said:
hey guys,
does this VD works for Netatmo Presence as well? Customer is trying it but all he gets is
API-Call was done - Call -Error. oAuth 2.0 returns nothing.
This is a script/scene to get the IP and the stream URL for the camera, it is not a VD. With the response of the script/scene you can add a camera to your HC2 with the stream of your Netatmo Presence/Welcome.
It seems that you you are using the wrong credentials to access the API, hence the error message you receive.
Sorry, yes I know it is scene :D
so the error may mean only wrong info from netatmo right?
According to @boomx the Netatmo Presence api is slightly different. In line 44 you will have to change the request body to
I have tried it at my end, and it works like a charm.
Edited by eGuard
corrections
If i add new camera for netatmo presence i see broken picture? Any idea ? What i could do wrong ?
Thanks,
Viljam
This works good, but if i have more then one camera, how do i proced?
The Script vill only find one Cam
With the last V4.511beta, I  have this error.
[DEBUG] 21:31:45: Debug: english
[DEBUG] 21:31:45: 2018-10-11 21:31:45.195583 [ error] Handshake error: certificate verify failed
[DEBUG] 21:31:45: 2018-10-11 21:31:45.196653 [ error] Handshake error: bad message type
, can you help us ?
, can you help us ?
try to add into GET request
checkCertificate = false
like i did for my scene
Hello all,
Here is the latest version of Netatmo Welcome camera finder scene:
Enjoy coding and your HA :-)
Guest CezaryF
Sankotronic i have problem . I write your code but in answer i have comunicate netatmo-oAuth connected. I add screen shot .Please help !
Hi @CezaryF ,
I have downloaded scene and check it again and it is working for me just fine. Did you properly setup your username. password, client ID and client secret?
I have exactly the same Problem :-( I have correctly setup username, password, client ID and client secret.
Guest CezaryF
22 godziny temu, Sankotronic napisał:
Hi @CezaryF ,
Hi @Sankotronic
does this now support the Netatmo Presence Camera
1. with light working
2. 2 x Netatmo Presence Camera's connected?
just new here@!
I have the same issue. Is there a solution for this problem available? I setup the script with all correct password, client ID and secret, but receive the same message as indicated in the screenshot above.
Arno
OK found it myself - following the hint from someone else in this forum.
In the source code the following needs to be changed from "camera" to "presence". Then it works!
function oAuth(nextFunction)
 local request_body = 'grant_type=password&client_id=' .. client_id .. '&client_secret=' .. client_secret .. '&username=' .. username .. '&password=' .. password .. '&scope=read_presence access_presence'
Arno
Hello @Sankotronic,
Thanks for this beautiful scene!! (I dont know why the scene of Boom gave error)
two questions:
- if I past the link in my VD Welcome scene it does not show a picture if I past the ink in my browser it show a pic of my Welcome, any idea?
/monthly_2020_04/image.png.33c11c547548bbf172ea2959cf63766a.png" />
How to retrieve the same info from my Presence camera?
Please advice,
//Sjakie
does this work with the nest hello doorbell too?
Perfect code, working fine!
So just to make small summary for the matter that @ArnoNym mentioned:
if you have Netatmo Welcome -> use "camera"
if you have Netatmo Prescence -> use "presence"
if you have Netatmo Doorbell -> use "doorbell"
Checked and all work well!
