Pop-up service
Guest Lode
In LUA you can create a nice pop-up notification with a lot of parameters.
You can create buttons that run a scene by pushing it.
It all works fine but the only thing i don't like is that you don't get a notification when you don't have the app open.
It would be much better to get a (sound)notification alert when the app is closed (but still running)
Together with popup notification send a push notification so then you will have sound and short message with push and also popup with details. That is how I did and it's working mostly fine, except when push and e-mail notification stop working since upgrade to 4.090 and above and have to reset HC2.:angry:
There is also another possibility with telegram which I intend to implement in my system as soon as I find more time to do it.
Guest Lode
    Sankotronic, yes i'm aware of that but for me it's only a half solution.
    It's not how it should be.
    I hope fibaro will come up with a solution, can't be that hard
    Thx anyway :-)
    I agree with you, but until Fibaro team do something about problem with popup notifications it is a good workaround at least for me.
    • 1 month later...
    Guest Lode
    Fibaroteam, i do understand that you are very busy but can you please tell us if there are any plans to implement this.
    I asked hundred of times if you can do something about it.
    There are thousands of apps who can do this so what's the problem ?
    • 3 weeks later...
    Where can i find info about how this pop-up works, so i can have 2 buttons?
    Like if the door is opened but lights is not on and it asks if you want to turn on lights? Yes or No :D
    You can have two buttons on popup notification and if pressed will start scene with ID specified. If scene Id is zero then nothing happens. See code:
